i drew an object, but later in the timeline. so, i can't use the add bone tool, since the object was drawn at frame 0, from what i gather.
is there a way to move this object back to the beginning so it is present at the frame 0 area for rigging. i can only draw the individual time line points back to frame 1. or perhaps there is some other way to do this?
rigging bones in an object drawn later in the timeline
- Víctor Paredes
Version 6 has the option of simply don't let you draw out frame zero. Personally, I unchecked this, but this implies be very careful.
But there is a simple solution, select all the keyframes created in the frame where you drew the object, copy and paste them on frame zero (now you can delete the out of zero keyframes).
Remember you can rig a character on frame 0 and make it invisible on frame zero and make it re appear on the frame you want. This is useful if you don't want a character since the animation begins.
- Víctor Paredes
- Víctor Paredes
Ok, I don't understand well your problem. I just emailed you the file with all keys on zero and no one on another frame.
I just copy and paste the frames again, on each layer. then delete all the keys except which are on frame zero.
I think your problem could be there were keys you didn't see and for this reason you didn't copy.
There are some keyframes which can't be erased, because it would be illogical. For example, the curvature channel. When you draw a shape, no matters in which frame, immediately will appear a curvature keyframe. All points you draw has their own curvature, there can't be a line without curvature (even when it's totally sharp).
So, if you created a shape, for example, on frame 20, you can't just erase the curvature keyframe, first you must have a support on a previous frame, I mean, a keyframe on a previous frame (zero, on the ideal case). That is what we made when copy all the keyframes on frame zero. Without doing that, many keyframes on frame 20 can't be eliminated.
- Víctor Paredes
Actually I remember there are a group of scripted tools which works just like this. Take a look on search, if I remember well, DK asked it.Imago wrote:It's possible have a similar function on ASP Pro 5.6, using script or something else?selgin wrote:Version 6 has the option of simply don't let you draw out frame zero.
