Vector Clouds
jorgy
Vector Clouds
Post by jorgy »
[Edited]
I would like to be able to have some clouds in moho that look something like:
I realize that this is a bit difficult with a vector program, but it should be possible with the effects, like shaded edges or soft edges. Maybe layering together different colors and blurring them?
jorgy
Post by jorgy »
I'm not sure why it didn't insert the picture and instead put the BBcode.
Let me try that again...
Hiddicop
Post by Hiddicop »
I suppose that the reason is that the URL has no extention. The forum is looking for a .jpg or .png or whatever extentions it can handle. The URL you posted dosn't have a accepted extention (as a matter of fact it dosn't have any extention at all) and therefor the forum ignores the BBCode and shows it as if it was plain text.
It sound like a reasoneble theory, and it even might be correct.
jorgy
Post by jorgy »
Hiddicop wrote:It sound like a reasoneble theory, and it even might be correct.
You are correct! Apparently snapfish URLs do not end with ".jpg", and so I moved it to another server and renamed it, and voila! Thanks for the hint.
idragosani
Re: Vector Clouds
Post by idragosani »
jorgy wrote:[Edited]
You might be able to create them with a particle system... but I am sure it would take a while to render. :-) One of the tutorials shows how to make smoke.
Perhaps you could generate the clouds in a different application (like a 3D renderer) and import them in as images...
or render the sky as a moving 3D background (with a 3D renderer) and composite with a Final Cut Pro, Cinelerra, etc.
Hiddicop
Post by Hiddicop »
Well, I gave it a try and came up with this. Not so good, I admit, but you could make it alot better. I might give another try later and make a better one.
But at least you can do nice clouds in moho. Even without any devestating render-times. This is just three vector-layers, and there quite simple. It takes notime to render it.
Hiddicop
Post by Hiddicop »
Here's the cloud above in action:
It actually looks quite good, evan though it's quite simple.
nobudget
Post by nobudget »
"You might be able to create them with a particle system... but I am sure it would take a while to render."
You can create the clouds with the Moho particle feature, export a couple of clouds as transparent bitmaps and import those. With rendered clouds you'll have no more long rendering times. The particle function can do quite realistic clouds easily with a bit of work.
Good luck,
Reindert.
www.nobudgetvideo.com
