image replacement on a rigged doll
Posted: Tue Mar 17, 2009 6:36 pm
by starchild
hey guys.
im using photoshop to create a cutout character on AS.
everything just fine but...
im wondering how can I replace the leg's images of
my already rigged cut-out character BUT still keep the bones setups and stuff intact for these legs im changing; (i think my bones are fine, i just wanted to change the legs images);
sorry if it's a dumb question to ask but i can't find an easy way to do it, and im sure there must be a very easy one.
Posted: Tue Mar 17, 2009 6:47 pm
by DK
Genete wrote this great little script for me that refreshes and replaces images from AS.
Cheers
D.K
ScriptName = "GE_reload_image"
GE_reload_image = {}
function GE_reload_image:Name()
return "Reload Image"
end
function GE_reload_image:Version()
return "1.0"
end
function GE_reload_image:Description()
return "Reload image form disk"
end
function GE_reload_image:Creator()
return "Carlos López (Genete)"
end
function GE_reload_image:UILabel()
return "Reload Image Source"
end
-- The guts of this script
function GE_reload_image:IsEnabled(moho)
if (moho.layer:LayerType() == MOHO.LT_IMAGE) then
return true
end
return false
end
function GE_reload_image:Run(moho)
local l=moho.layer
if(l:LayerType()~=MOHO.LT_IMAGE) then
return
else
-- print("reloading...")
l=moho:LayerAsImage(l)
local fname = l:SourceImage()
l:SetSourceImage(fname)
return
end
end
Posted: Tue Mar 17, 2009 7:07 pm
Or in the image layer's layer settings, image tab, you just need to assign the new source image. That script is for updating a changed image, but it sounds like you want to swap images.
Posted: Wed Mar 18, 2009 3:25 am
You can always assign a new image for one which already is imported and rigged. Just go inside the layer properties and assign a new source.
If you don't see a change, just close the AS file and open it again. It now has updated all image information.
Posted: Wed Mar 18, 2009 3:36 am
by DK
Slowtiger, This is what the script that Genete wrote, (above), does without the user having to close and re-open AS. It's a real timesaver for people who use a lot of images in their work. It came about when I was using image sequences in a project and photoshopping them as I went along but was frustrated with AS not refreshin the source sequence without shutting down and re-assigning etc hence a thread on the forum resulted in this Lua script from Genete. it's fantastic!
Cheers
D.K
Posted: Mon Dec 05, 2011 3:05 pm
by Spence
Hi DK...
I realise that this is an old thred but I cant seem to get the ge_reload_image.lua script to work?
In another post you said you deleated the ******'s. This too doesn't work for me? could you take a look at the script you've installed and copy it!
Ta,
Spence
Posted: Mon Dec 05, 2011 3:30 pm
by DK
Hi Spence.
PM me with your email address.
Cheers
D.K
