My First Animation Ever
JeffZHigs
Post by JeffZHigs »
http://neverendingshortcut.blogspot.com ... ridge.html
I hope you guys like it, I know its not the best, pretty horrible, but I've never used these vector points before, and I'm just figuring it out. Got any tips? I'd love to hear them.
I'm a rookie animator, and am trying to get it right, slowly but surely
GCharb
Post by GCharb »
Hello Jeff
First of, it aint too bad, I would use some stretch and squash on those tomatoes, would make them look tons better.
Your frig door could use some perspective too, here's a trick I just discover about AS perspective points while I was searching for a way to help you, you can set a pivot point for them real easy, meaning you could draw an inside of a frig door then open it in perspective real easy.
1. Draw your door with two sides at frame zero, with a line of points running in the middle, that will be your pivot axis.
2. go to a frame, say, 12, use the Perspective Points tool then drag your mouse util you get your door open the way you want it.
3. Delete the side you do not need.
frigdoor.zip 2.27 kb
Hope this help
GC
Hey that's a pretty good trick. I'll have to remember that one. :wink:
GCharb
Post by GCharb »
synthsin75 wrote:Hey that's a pretty good trick. I'll have to remember that one
Heheh, am a fast learner! :)
I used to make pretty good tutorials, find them usefull for learning, might do a few on AS Pro.
GC
JeffZHigs
Post by JeffZHigs »
GCharb wrote:Hello Jeff
Hope this help
GC
Helped alot, thanks for the advice.
