Add a "stationary" keyframe.
Posted: Thu Nov 20, 2008 2:51 am
Hey, might get this one a lot and maybe I just need to add a script or something but I wondered if there was a way to add a keyframe in the timeline that would capture the current frame as is. So for instance......I have a stationary ball at frame one and lets say I go all the way to frame 100 and I move it to the left side of the screen, the result will be the ball moving across the screen from frame 1 to frame 100. But lets say that I want the ball to start moving in frame 50. I know from using after effects that this would be accomplished by going to frame 50 and just adding a keyframe. But of course AS is more advanced in some ways than AE so it may be different.
I guess this question reveals just how new I am to this program. Thinking about it now I'm not even sure I know what I'm asking. The truth is I'm not trying to animate a ball. I have a "character" with points and curves and such and I have rigged a skeleton to the character. Now when I go to frame 10 and change the position of the skeleton it automatically makes new keyframes. But my problem is that when I would then go to frame 20 and change the position of the layer, instead of seeing the layer begin moving at frame 10 and move to the new position by frame 20 , I see the layer move from frame 1 to frame 20. Am I in turn stuck with having to manually add keyframes for each channel that I want to remain constant during certain sections? Or is there a way to ask for all channels to record the current position for everything.
Thanks for your help.
