Speeding up performance BIG TIME!
Posted: Wed Oct 15, 2008 10:48 pm
Holy cow! Holy freaking cow! Maybe some of you already know this but it's new to me.
Imagine you have a huge AS file with bunches and bunches of image layers. I noticed this first with a huge file that had 20 image layers that covered the entire render area.
I needed to draw boxes on a vector layer over an image layer. I had ten group layers with two images each and a vector mask layer between the two images. Each image covered the entire render area, basically hiding everything below it. I would start with layer 1 only "turned on" or visible (the eyeball thingy) and as I moved up would just turn on the next layer.
Layer 1 was fast and speedy. As I got closer to the top (more layers "on" but not "hidden" or covered) performance started to drag and slow WAAAYYY down. It never occurred to me that even though I couldn't SEE all the other image layers hidden by the upper layers they were still being "rendered" in the preview. They were using resources. If I turned off all the other group layers below the one I was working on (basically turning off all the performance robbing image layers) performance increased 10 fold.
In other similar files this was not as noticeable because I usually only had 5 or 7 layers. I never had one with 10 layers before.
I hope this helps someone. It's new to me.
p.s. I guess this could be a "feature" request. If a layer is totally covered it shouldn't be included in the render buffer to improve performance.
