Very Very Very Bad PNG Quality In VCD .
Posted: Tue Oct 14, 2008 11:28 pm
by mohsen123
hi there .
I'm really wondering . in all of animation I use 8 Bit PNGs in RGB color . have a edit in UleadVideoStudio and export in a good qulity...
but in VCD format quality is really really down . I know the reason is not in my write because when I create VCD in my PC there is some bad breaks in outline s of png files .
VCD image :
DVD image :
how can I fix this animation in VCD with a tolerable quality ?
is there any problems in my color depths ?
thanx
Posted: Wed Oct 15, 2008 1:35 am
It's not the colour depth but the resolution. Somehow the VCD image has only about 150 x 90 pixels, stretched to the viewing size of 456 x 274. It looks like you're only rendering a preview. Check all of your dimension settings.
Posted: Wed Oct 15, 2008 2:49 am
by mohsen123
hi slowtiger thnx
ye VCD is too low size . but what I'm wondering is just that there is many VCDs with good tolerable quality . I was try to write another Cartoon in VCD the result quality is so much better then result of VCDs of animestudio renders !
Isent there any problem about this resize ? for example I create scene in same size with what I will render . hum ?
t h a n x
Posted: Wed Oct 15, 2008 3:58 am
The dimensions for a VCD, according to spec, should be 352 x 240 (NTSC) or 352 x 288 (PAL). Whatever your video software generated, it's not the correct format.
