Delete freehand tool outline
Posted: Mon Feb 28, 2005 7:06 pm
by riledguy
How do I delete the outline of shapes I have drawn with the freehand tool? I uncheck the box for "enable outline" but it still shows up.
Posted: Mon Feb 28, 2005 7:38 pm
by myles
You need to select the shape first using the Select Shape tool (it looks a bit like a white kidney bean holding a black umbrella).
Easy to do if your freehand shapes were drawn using Auto Close and Auto Fill, you can just click on the fill area - the fill will change to a checkered pattern.
If your shape is an outline only, it helps if you first zoom in on a portion of the shape's outline, so it is easier to see if you have successfully selected it (the outline colour will change into a checkered pattern)
Regards, Myles.
Posted: Mon Feb 28, 2005 7:47 pm
by riledguy
myles wrote:You need to select the shape first using the Select Shape tool (it looks a bit like a white kidney bean holding a black umbrella).
Regards, Myles.
I have done this. My problem as I stated is that when I uncheck the outline box after the shape is selected it is still showing a black outline. I need to get rid of this somehow. Telling it to not have an outline does not seem to do the trick.
Posted: Mon Feb 28, 2005 8:05 pm
by Lost Marble
Are you sure you're not just seeing the editing curves that make up the shape? If you render the result, do you still see the outline?
Posted: Mon Feb 28, 2005 8:21 pm
by riledguy
Lost Marble wrote:Are you sure you're not just seeing the editing curves that make up the shape? If you render the result, do you still see the outline?
I am sure it is not the editing curves. I render out the frame and my tree highlights are all outlined in black. I drew them with a wacom pen and all the various line weights are still intact also. Even with the box unchecked there is no change in them. I could in therory hide all the lines so that just the fill shows but that would be a real pane in the ass. There are a lot of lines.
Posted: Tue Mar 01, 2005 5:32 pm
by myles
riledguy wrote:I render out the frame and my tree highlights are all outlined in black.
Hmm. So you select a particular highlight (with the Shape Select tool, not the normal Point Select Tool ), and only the highlight goes checkered, not the normal tree fill, right?
The Style Panel shows the fill and outline details of the highlight you've selected, yes?
Are you applying a named Style for your fills and outlines, or just using simple individual fills?
Regards, Myles.
Posted: Tue Mar 01, 2005 6:22 pm
by Lost Marble
There's something funny going on here - we need to see the Moho file. If you can, put it up on a web site and post a link. Otherwise, email it to support@lostmarble.com
