Render sequences with field
PrimeNoob
Post by PrimeNoob »
Hi everybody! Somebody know how can I render a TGA sequence with (Upper or Lower field) like in Premiere. I need a better output on TV, cuz the lines now are too fragmented.
Somebody with the same problem? Any experience?
Thank you in advance!
Not possible in AS. Alloutput is by default "progressive". If you experience broken lines the mistake must occur later in the workflow. One tip: avoid horizontal or nearly-horizontal lines of less than 2 px thickness.
PrimeNoob
Post by PrimeNoob »
slowtiger wrote:Not possible in AS. Alloutput is by default "progressive". If you experience broken lines the mistake must occur later in the workflow. One tip: avoid horizontal or nearly-horizontal lines of less than 2 px thickness.
Thank you! Eventually we use outlines with 2px thickness. What do you think, maybe it can be helpfull a small blur on the lines? :roll:
