Where are all the tutorials?
Posted: Wed Feb 23, 2005 9:03 am
by DK
I had to re-install Moho today and went to look at the tutorials but there appeared to be only a few available from the help file. Are the tutorials completed yet? If so where can i download them? (sorry,...I've probably missed something along the way).
D.K
Posted: Wed Feb 23, 2005 9:09 am
by Hiddicop
I don't know whats wrong, but incase something is wrong I'll let it over to Lost Marble.
But I just want to mention that the help-files can also be found att the following adress, just in case you need them quickly:
http://www.lostmarble.com/moho/manual/index.html
Posted: Wed Feb 23, 2005 9:13 am
by DK
Thanks Hiddicop
I wonder if there is a zip file available for the tutorials?
D.K
Posted: Wed Feb 23, 2005 10:56 am
by Lost Marble
Are you looking for the tutorial .moho files, or the tutorial walkthroughs in the manual?
The tutorial .moho files are located in the Moho program folder:
.../Moho/Tutorials
On Windows this is typically:
C:\Program Files\Moho\Tutorials
On Mac OS this is usually:
/Applications/Moho/Tutorials
The tutorial walkthroughs (the textual descriptions) should be in the manual. On the left side of the manual (the table of contents), click the Tutorials links to expand that section, and then go to the tutorials that you're interested in, "Basics", "Drawing", "Bones", etc.
Sorry if that didn't really help, but I'm having trouble understanding exactly what files seem to be missing?
Posted: Wed Feb 23, 2005 1:26 pm
by DK
Hi LM.
Thanks for the the answer....but i re-downloaded the entire Moho install and everythings fine....for some reason half of the tutorials from the earlier re-install of Moho were not active links just headings in the tutorial section of the help file.
D.K
Posted: Wed Feb 23, 2005 1:51 pm
by Lost Marble
Hmm, that could have happened if you installed one of the beta version before the manual was finished. Otherwise, I have no idea...
Posted: Wed Feb 23, 2005 3:04 pm
by bupaje
You have any new security software or security updates recently? I know the index of the help file uses javascript and the last XP upgrade makes it generate a warning -you might see a yellow bar at the top of IE if this is what you have as well and you have to click on it and 'allow active content.' Unfortunately seems you need to do that each time unless you loosen up the security settings a bit which I don't want to do ....
