Page 4 of 4
Re: Smart Bone Helpers by Ramón López
Posted: Tue Oct 14, 2014 9:35 am
by Rai López
KuzKuz wrote:Hi, need this wonderful script fix for ASP 10.1.1. Thanks!
...Oh, yes! Thankfully I already made a quick fix for this, so now it's only an upload matter. Here is the new link: It is kind of a "mend" but it should do the job for 10.1.1, anyway... let me know whatever you consider appropriate. Greetings!
Posted: Tue Oct 14, 2014 9:51 am
by Stan
Ramón López wrote:It is kind of a "mend" but it should do the job for 10.1.1, anyway... let me know whatever you consider appropriate. Greetings!
Hey Ramon, I just want to add my 2 cents. Here's how I solved the same problem in my scripts:
	if moho.AppVersion ~= nil then
		local sVersion = string.gsub(moho:AppVersion(), "^(%d+)(%.%d+)(%..+)", "%1%2")
		version = tonumber(sVersion)
	end
That simple pattern will always return an appropriate number from any string versions like "11", "11.1", "11.1.2.1111", etc.
Posted: Tue Oct 14, 2014 10:25 am
by Rai López
Stan wrote:Hey Ramon, I just want to add my 2 cents. Here's how I solved the same problem in my scripts:
	end
Wow! I'll study that thanks! :D
I'm currently out of shape about all this and I had to make a quick fix that I knew it was not going to be perfect under all the possible situations (as someone pointed afterwards), but I left that way because it was the nearest solution I could find at that moment. Of course, I always wanted a simpler and more trustworthy solution, something more like yours seems to be, at least at first sight and for what you say, because I have to re-learn how to deal with strings as soon as I stop doing in a daily basis... Anyway... it's so/very welcomed! So thanks again :)
Posted: Tue Oct 14, 2014 10:58 pm
by KuzKuz
Thanks! :D
Posted: Wed Oct 15, 2014 1:18 am
by Lukas
Thanks for the quick fix Ramón!
Posted: Wed Oct 15, 2014 2:55 am
by Rai López
You're all welcome! :)
Posted: Wed Feb 24, 2016 5:30 pm
by sillyanimate
um where do i put the pictures??!??!
