Page 3 of 3
Re: LK_LayerFinder
Posted: Tue Oct 10, 2023 4:14 am
by Lukas
Thanks Rai!
I honestly don't understand why it's crashes and why your extra line of code fixes it. But I'll add it to the script for now
Thanks!
Hope this all gets addressed in an update.
Re: LK_LayerFinder
Posted: Wed Oct 11, 2023 10:18 am
by Rai López
I'd be happy if it finally helped, Lukas! The key is, even though I don't understand either why it seems to work due to whatever is happening happens internally, for some reason the temporal "bait" dialog somehow gets to cheat Moho just in the right moment, that is to say, when Moho's dialog messages system seems to start getting messed up and, fortunately, once passed that point you can do anything one would expect to can do with the now safely open dialog without problems, or at least that's my experience on the absence of further confirmations...
BTW, we have talked about it several times and probably devs are already aware of it, but I don't think it has been officially reported, isn't it? Although I could be wrong, so I'll try to find out and do it if not. Providing the details and the steps of my previous post to can systematically reproduce the crash should help them to get to the bottom of what can be really going on under the hub, (again) hopefully... Cheers!
Re: LK_LayerFinder
Posted: Sun Aug 31, 2025 8:59 am
by Gherasimov Vasile
Hello colleagues, I want to thank Lukas for this wonderful script, it helps me enormously, but I had a problem with it: Moho always closed when I used it. Chat GPT helped me understand why and modified the code, and it works on the first try... I can give you the script for those who have the same problem. I'm attaching it in a link on Google Drive. So, from what I understand, the problem was that the script always updates the layers, which slows down the Moho process. Chat GPT suggested a button that I can use to do this update manually.
https://drive.google.com/drive/folders/ ... sp=sharing
Re: LK_LayerFinder
Posted: Mon Feb 23, 2026 2:18 pm
by Lukas
There's an improved version here:
https://mohoscripts.com/script/lk-layerfinder
It now uses a menu list instead of a lot of buttons, so there's no keyboard modfier to select mutliple layers unfortunately. But there's a toggle for selecting (keyed) child layers, and a red 'recording' button which can be disabled to stop the window from hogging resources
Re: LK_LayerFinder
Posted: Mon Feb 23, 2026 3:09 pm
Oh my! I somehow forgot about this tool.
Will download the update and try it tonight. Thanks for sharing and keeping it updated, Lukas.
