Moho 13.5.1 update is available!
Re: Moho 13.5.1 update is available!
Ok, thanks for confirming Daxel. I'll pass on the info and point the devs here.
It's the latestGreenlaw wrote: ↑Sat Sep 18, 2021 8:20 amTo be clear, is this with the latest version 13.5.1? Auto-save crashing was a problem in the very earliest 12.0 releases, but was fixed almost immediately, then it resurfaced with 13.5 and I believe it was worked on for 13.5.1, so just checking if it needs to be looked at some more. Also, what OS are you using? If you can provide any more technical info and anything specific you might be doing, this might get solved quicker. I can let the devs know in case they miss your post.
FWIW, I keep Auto-Save enabled and I ran it for several hours at work last week without crashing. (Running with latest Win 10 update and latest nvidia drivers.) Regardless, it's a habit of mine to make frequent incremental saves in any program I'm working in, with Auto-Save enabled or disabled.
That said, I recommend trying Wes' script too. I haven't used it with Moho 13.5.1 but it worked well for me in the past, and it can even save incremented versions automatically!
Image removed by the forum admin- synthsin75
You might not want to show the whole world your serial number.
That's strange. Maybe you could share a file with us and with support deleting everything except the problematic element to see if we can reproduce the problem and it is a bug or not.
Sorry My bad didn't notive what i was looking at thanks for the edit/deletesynthsin75 wrote: ↑Tue Sep 28, 2021 12:52 pm You might not want to show the whole world your serial number.
I no longer have the files because i deleted them/alt save them in different back up, when ever i get this issue where the program just crash on me i just open the file again (and delete the smart bone key frames and redo everything again) it occasionally happens when i'm fiddling inside a smart bone sometime's it's when i move a vector point. It may vary from other people but for me it's this one that i notice.
