MR Curve Tool 4.1
KuzKuz
Re: MR Curve Tool 4
Post by KuzKuz »
The script has been updated to version 4.0.7. Fixed a bug with Bezier handles on FBF layers.
Re: MR Curve Tool 4
Hi Eugene!
Today, I re-watched all four videos for MR Curve, and I'm so glad I did that because I was missing out on several features!
I encountered a problem with one feature: When I use Ctrl+Alt to subtract from the current selection of points, as shown in the 3.0 video, MR Curve instead deselects everything. Has this shortcut changed in 4.0? (4.0.9.)
Thanks in advance for any tips!
KuzKuz
Re: MR Curve Tool 4
Post by KuzKuz »
Hello, it seems to be a bug, I'll try to look into fixing it tomorrow.
Re: MR Curve Tool 4
Hi Eugene!
Thanks for looking into it. This bug is not a show-stopper, so whenever it's convenient for you is much appreciated.
Here's another one I found this morning...
In this example, I'm using the Ctrl key to make sharp corners on the ends and no key to make the Smooth point in the middle. The created shape looks good, except the sharp corners are not actually 'peaked' and they do not have rounded edges. I get the round edges only after I select the points and apply Peak.
Also, if I don't 'peak' the sharp corner points, and I try to move them using the Transform Points tool, the point does not move. Instead, a Bezier handle gets drawn out.
BTW, I've been using MR Curve constantly this week and it's been fantastic even with these small errors. My mousing arm and wrist thank you! Please keep up the excellent work! :D
KuzKuz
Re: MR Curve Tool 4
Post by KuzKuz »
Greenlaw wrote: Thu Jan 18, 2024 2:40 pm Hi Eugene!
This is not a bug, it's a workaround for a bug. If a point has a curvature of 0, then creating points with Fixed Bezier on neighboring segments will result in broken handles. Therefore, the Curve Tool will create points with a curvature of 0.001 so that points can be added to the segments without broken handles.
I think I can make this optional, in case there is a need to create simple shapes rather than drawing complex figures.
KuzKuz
Re: MR Curve Tool 4
Post by KuzKuz »
Version 4.1 for testing.
Ctrl+Alt now should remove the selection from points. Also, I've added the option 'Use Peak for corners'.
Please let me know if everything works well and nothing is broken, so I can publish this version on mohoscripts.
Download the script - https://drive.google.com/file/d/1I5aQ_s ... sp=sharing
Re: MR Curve Tool 4
KuzKuz wrote: Fri Jan 19, 2024 6:50 am This is not a bug, it's a workaround for a bug. If a point has a curvature of 0, then creating points with Fixed Bezier on neighboring segments will result in broken handles. Therefore, the Curve Tool will create points with a curvature of 0.001 so that points can be added to the segments without broken handles.
Oooh...this seems to be related to an Add Points bug (already reported) I ran into shortly after seeing this MR Curve behavior.
Thanks for explaining why MR Curve is doing that. The fix might be good, but just being aware of this for now is helpful.
Re: MR Curve Tool 4
KuzKuz wrote: Fri Jan 19, 2024 8:40 am Version 4.1 for testing.
That was fast! Thank you, Eugene. I'll be using this version today.
Re: MR Curve Tool 4
Ctrl+Alt to subtract from a selection works now.
The new Use Peak For Corners option is working well for my example. I'll work with this option on and off throughout the day to make sure I understand the practical uses. I will let you know how that goes.
Thanks for addressing this so quickly! :D
Re: MR Curve Tool 4
Hi Eugene,
I've been working with MR Curve 4.1 most of the day, and I have a better understanding of when to use the Use Peak For Corners option. I was drawing many small tears in clothing, and enabling the option helped there. It was when I started drawing larger, curvy items where I had to go back and insert many smooth points that I found it was better to turn this option off.
Thanks for adding this option. So far, 4.1 is working out well for me! :D
KuzKuz
Re: MR Curve Tool 4
Post by KuzKuz »
Thank you for the feedback. I have published version 4.1 on mohoscripts.
amanandink
Re: MR Curve Tool 4.1
Post by amanandink »
Hey Just a heads up Eugene, the mohoscripts download seems to be missing the mr_utilities file, i just downloaded and installed it from there and i kept getting an error in the lua console. But I found the file in the download link you have a couple of posts back on here. When i added it the error went away.
Jeremy
KuzKuz
Post by KuzKuz »
Thank you. I've fixed it.
