Bone morph dials script
kefen109
Render error in AnimeStudio7 but works in AnimesStudio 6
Post by kefen109 »
I tried this script in Anime Studio 7 but Not render in Anime Studio 7.
Then I tried to render in Anime Studio 6 and It works fine.
ulrik
Re: Render error in AnimeStudio7 but works in AnimesStudio 6
Post by ulrik »
kefen109 wrote:I tried this script in Anime Studio 7 but Not render in Anime Studio 7.
Could it be that it works to render in v.6 but not in v.7, cause my version 7 always crash when rendering?
How about you funksmaname, have you tried the script in version 7?
sbtamu
Post by sbtamu »
sbtamu wrote:This is my 1st try at using MorphDials. I just tossed a mouth on AS prop hair and eyes and only used 4 phoneme.
http://www.youtube.com/watch?v=mZ0BztguZdw
I'm glad I finally got it to work!
Thanks for the help!
Stephen
This is with AS7 pro and It renders just fine with Morphdials and never crashes. Windows XP, 32 bit
Sorry for bad animation
ulrik
Post by ulrik »
Stephen
hmm..ok, well for me (on mac) it never works, the lua consol pops up and AS crashes, unfortunately the lua consol freeze and is unable to write a report. :(
Onionskin
Post by Onionskin »
When I start to render it crashes by me also, ASP7 W7 64-bit, and on 32-bit also. On XP is works fine.
Rudiger
Post by Rudiger »
It crashes for me also (AS7 + W7 64-bit). The fact that AS6 worked fine for everybody points to a bug in AS7. Very interesting that it seems to work on XP, though.
I'm going to try and boil it down to the simplest case possible that still causes a crash and report it to Mike. Hopefully, I'll get it done before 7.1 gets released.
In the meantime, you could try removing the embedded scripts and using the bake method instead.
ulrik
Post by ulrik »
Rudiger wrote:It crashes for me also (AS7 + W7 64-bit). The fact that AS6 worked fine for everybody points to a bug in AS7. Very interesting that it seems to work on XP, though.
Yes that would be great, thanks!
:shock: OH NO! i've not tried in AS7 yet, it would be extremely dissapointing if it really is broken!! :( I'll try it as soon as I can and report back...
sbtamu
Post by sbtamu »
Hold the phone, I just looked at my morph vid, It was not rendered, I just did a screen capture, I'll render now and see if it really does work on AS7 pro.
For me, script works, rendering single frame (ctrl+R) works, but when you try to export a movie it instantly shuts down without error... *sob* tis a sad day.
sbtamu
Post by sbtamu »
Works on AS7 Pro, Windows XP 32 bit, rendered as AVI uncompressed.
http://www.youtube.com/watch?v=2uXlUxLhvwA
I'm on vista 32bit, AS7, exporting insta-crashes regardless of codec... i dont think it's a codec issue tbh... Stephen can you post your file? i will try and render it this end.
Do you ahve any other scripts installed?
D.
sbtamu
Post by sbtamu »
funksmaname wrote:I'm on vista 32bit, AS7, exporting insta-crashes regardless of codec... i dont think it's a codec issue tbh... Stephen can you post your file? i will try and render it this end.
D.
Sure no problem.
ATM I have Two Way Ticket, Adjust colors, and MorphDials no others scripts on the PC.
here is file...
http://www.sendspace.com/file/zb5c5m
Stephen
nah, it crashes here... do you have fazeks tools installed?
sbtamu
Post by sbtamu »
funksmaname wrote:nah, it crashes here... do you have fazeks tools installed?
Just the 3 scripts; Two Way Ticket, Adjust colors, and MorphDials I do not have fazeks tool on this PC.
Send me a simply animation with morphdials and let me see if I can render your setup.
Stephen
