Page 2 of 2
Re: Halftone Print
Posted: Fri Jun 19, 2026 7:11 am
by J. Baker
Huge improvement! I added a Lumin channel and it looks much better.
I will keep working on this and making it a single CMYK file to simplify it a bit. Also want to get the angle print back but on the single file as stated.
Download Removed - See my next post.
EDIT: Added a color test pattern at the top and CMYK rotation.
Re: Halftone Print
Posted: Fri Jun 19, 2026 8:27 am
by hayasidist
J. Baker wrote: ↑Wed Jun 17, 2026 7:20 pm
... Maybe tomorrow I will create a zip file containing all this if anyone is interested.
looking good! well done. love to see the (updated) .zip if you're still up to sharing it.
Re: Halftone Print
Posted: Fri Jun 19, 2026 9:22 am
by J. Baker
hayasidist wrote: ↑Fri Jun 19, 2026 8:27 am
Here it is!
This uses a single CMYK image filter and 50% lumin filter to adjust for the offset of brightness. This should be perfect for classic comic style print or animation. Render a frame and zoom in to see. If you need a higher res CMYK image for your own project, just let me know.
Download Zip File
Preview Gif
Re: Halftone Print
Posted: Fri Jun 19, 2026 10:22 am
by J. Baker
I've updated the download link above (minor adjustments to masking and note added) and the preview GIF. Just in case anyone has downloaded it. I also changed the link to my website instead of a freebee website that only lasted 7 days. Enjoy!
Re: Halftone Print
Posted: Sat Jun 20, 2026 2:02 am
by hayasidist
J. Baker wrote: ↑Fri Jun 19, 2026 10:22 am
Thanks! (no preview .gif in the .zip, but no biggie - and yes - did check that I used the posemotion link!)
One approach you might like to consider for applications in larger formats than the 1000*800 px in your (excellent) demo: rather than the cmyk.png as a layer - I replaced it with a moho vector shape that uses the .png as an image texture set to tile, then the effects handle can scale and rotate the whole. This vector layer has the same attributes as the baseline .png.
(but I also guess you could generate a .png larger than to 1024px square that you have here?)
Re: Halftone Print
Posted: Sat Jun 20, 2026 6:55 am
by J. Baker
hayasidist wrote: ↑Sat Jun 20, 2026 2:02 am
Oh, the GIF preview is on the forum here in the same post as the download.
I'm not sure what you mean on how you replace it? I originally tried a vector file but Moho couldn't handle that many vector dots. Locked my system up anyway.
EDIT: Oh, I see. You tiled it inside a vector layer. Very smart.
Yes, I can make larger PNG files if needed. I have it coded in PureBasic.
