Re: Possible to stop vector lines from becoming shapes when importing SVG files?
Posted: Wed Dec 01, 2021 5:49 am
Wow, never tried the save as always used export this really works so much better. I use Corel Draw! and the AI always had double lines it treated lines as shapes and gave an outline! And of course older versions of Moho 'AS' there were just too many points to deal with. The SVG when I import it into Moho nothing happens at all? mine only goes up to 1.1 also the AI is version 8 ( I think that's the highest Moho will allow)Greenlaw wrote: ↑Mon Nov 29, 2021 8:22 pm
I don't use Affinity Designer but I know that in Adobe Illustrator I need to use the Save As... command (in other words, not the Export... command,) and choose .SVG as the format. Then, from the settings window that appears when you click Save, choose SVG Tiny 1.2.
Using this specific .SVG format will save the shapes with their fill and stroke properties for Moho, and any of the earlier format will not. I'm going to assume the same rule applies to Affinity Designer's SVG exporter.
