Page 2 of 3
Re: A script to import TVPaint's CSV file format
Posted: Tue Aug 16, 2016 1:05 am
by Fazek
You can find a new version on the download page, I hope it's working now.
Posted: Tue Aug 16, 2016 1:32 am
by ulrik
Thanks for the script, it's working here with TVP 10 and Moho 12 on OS X
Posted: Tue Aug 16, 2016 8:50 am
by Fazek
ulrik, please download and try the new version I just uploaded. The problem is the new directory structure of the CSV 1.1 format (I think TVPaint implemented this recently in version 11).
cartoonmonkey, please, if you want to help me with testing, please try the new version with your files, and also move (ie. copy the files and delete the originals) your test.csv file and your test.layers folder to a different location on your harddisk, then try to load them from there.
Thanks
Posted: Tue Aug 16, 2016 12:39 pm
by ulrik
Fazek, the latest version works just fine here, even if I move the csv file and the layers to another location. TVP Pro v.10, Moho 12, OS X 10.11.6
Thanks once again for this script!
Regards Ulrik
Posted: Thu Aug 18, 2016 4:31 pm
by cartoonmonkey
Working well with TVP 11 Pro!
Cheers!
C
Posted: Fri Aug 19, 2016 9:22 am
by cartoonmonkey
Now if only Moho would export CSV as well...
Posted: Thu Aug 25, 2016 12:14 pm
by Fazek
cartoonmonkey wrote:Now if only Moho would export CSV as well...
Actually it's not a completely impossible wish. But only if Moho is able to render the current frame from lua. I'll check the possibilities, it's a good idea.
Posted: Thu Aug 25, 2016 1:56 pm
Fazek wrote:cartoonmonkey wrote:Now if only Moho would export CSV as well...
moho:FileRender(path) renders the current frame to the image format given in the path file name extension.
Posted: Sat Aug 27, 2016 10:50 am
by Fazek
A new experimental export plugin is avaliable now. I've also fixed the import plugin: importing layers with empty first frames was buggy.
About the export plugin: It exports the top level layers as separate layers. If a top level layer is a group, the plugin renders its contents together. But it expands top level group layers if the group has no masking and it contains switch layers only. Basically this is the "inverse" of the import plugin. If a layer is a still picture (vector or image), it tries to render only the changes. If the layer or the camera has ANY animated keys, it renders all frames of the layer separately.
The the render window shows up for each exported image with an annoying beep sound (at least for me). So it's flashing and beeping like crazy during exporting. Sorry for that, I don't know yet how to avoid it.
Posted: Sat Aug 27, 2016 11:11 am
Fazek wrote:The the render window shows up for each exported image with an annoying beep sound (at least for me). So it's flashing and beeping like crazy during exporting. Sorry for that, I don't know yet how to avoid it.
I don't think there's a way to avoid that. The user can disable audio feedback in the preferences if the beeping is really annoying.
Posted: Wed Aug 31, 2016 2:18 am
by ulrik
When exporting csv from Moho on OS X, is there a way to stop the rendering?
I ask because I started a csv export from a big project and while rendering I noticed that I had forgotten to fix a layer and wanted it to stop,
I tried with esc and command+. but I had to use force quit
Regards Ulrik
Posted: Wed Aug 31, 2016 4:53 am
by Fazek
Hello Ulrik,
To do such things like capturing keystrokes, processing dialog messages etc. the script should return the control back to the main program and gain it again during the rendering. This is a simple menu script with a linear workflow. The user control you want is perhaps possible, but these things are making the code very complicated. Perhaps instead of tricks, there supposed to be an official way to abort runaway lua scripts nicely, without quitting the program.
Posted: Wed Aug 31, 2016 5:45 am
by ulrik
Ok, I understand, thanks!
Regards Ulrik
Posted: Wed Aug 31, 2016 9:21 am
I noticed in the code that you were looking to get the Moho version:
const char *AppVersion()
Yeah, I can't think of anyway to allow the user to interrupt the rendering without also making them babysit the rendering by periodically telling the script it's okay to continue.
Posted: Wed Aug 31, 2016 9:39 am
by Fazek
Hello synthsin75,
Yes, I noticed it too and probably I will change the current (.moho vs. .anme) solution to that.
About the abort functionality: perhaps if i exit the script after each rendered frame and force the system somehow to call it back again for the next frame... but it seems difficult.
