Page 2 of 2
Re: PC version has lag when using "sticky key" feature
Posted: Tue Aug 09, 2016 6:47 pm
by Fuzatron
Awesome!
I hated to ask. If you find the time, it'd be much appreciated.. again :)
Posted: Tue Aug 09, 2016 7:21 pm
Posted: Tue Aug 09, 2016 7:30 pm
by funksmaname
AH! thanks for this Wes - I noticed this problem but had no idea what it was :P
FYI, this is a quick way to add it to Win10 startup:
http://www.howtogeek.com/208224/how-to- ... ndows-8.1/
Posted: Tue Aug 09, 2016 7:44 pm
by Fuzatron
synthsin75 wrote:Here's the fix for Moho 12.
https://dl.dropboxusercontent.com/u/536 ... %20fix.zip
And all is right with the world again.... Well, at least with drawing in Moho anyway ;)
Big thanks again, Wes!
Nice tip, Funks :)
Posted: Tue Aug 09, 2016 7:46 pm
It was simple to update...no problem at all.
Posted: Sun Aug 01, 2021 4:15 am
This problem from AS 11.2 is still an issue for 13.5 on Windows 10. Luckily, my above fix, updated for Moho 12, still works for 13.5.
Posted: Fri Feb 10, 2023 6:53 am
by mgo
Wes, thanks so much for the fix.
Posted: Fri Feb 10, 2023 3:58 pm
Always happy to help.
Posted: Fri Feb 10, 2023 4:10 pm
Oh, I wasn't aware of this fix! Thanks for posting the solution Wes.
I generally avoided using sticky keys in Moho because I thought the lag was normal when a Moho project reached a certain complexity or number of keyframes.
Will check my Repeat Rate to see how it makes a difference for a heavy project file, and then try the script to fix it specifically for Moho.
Posted: Fri Feb 10, 2023 4:43 pm
I took a few minutes to play around with this.
I checked my Repeat Rate and Repeat Delay setting and they were already set to the fastest/shortest settings.
For me the lag occurs most noticeably when the Style window is left open (as Wes noted,) even with a fairly simple project file. It's really bad with a more complicated project. When I close the Style window, Sticky Keys is reasonably speedy. Leaving the Tools or Switch Selection window open has a minimal lag effect...it's there but barely noticeable compared to when the Style window is open.
I guess this is fine for me because I normally keep my Style window closed during animation, but knowing specifically what causes the lag is very helpful!
Hopefully this lag with the Style window open gets properly fixed in a future update.
Posted: Sun Sep 17, 2023 3:25 pm
by Fuzatoon
So the problem remains in 14 :!: but thankfully this fix still works 8)
Thanks again, Wes!
Posted: Sun Sep 17, 2023 7:27 pm
Fuzatoon wrote: Sun Sep 17, 2023 3:25 pm So the problem remains in 14 :!: but thankfully this fix still works 8)
Thanks again, Wes!
Happy to hear the fix is still working.
