Page 2 of 2
Posted: Mon Sep 27, 2010 6:56 pm
by freecartman™
Hi, i used the morphdials in combo with selgin's technique (thanks to Rudiger's scripts) and everything works, i'm just having troubles in exporting...every time i try exporting an animation, AS crashes...have you had the same problem?
Posted: Mon Sep 27, 2010 8:45 pm
by funksmaname
this is a recently descovered issue with the multithread rendering
it crashes when using morphdials or meshinstance (or both) on AS7 ONLY on machines using multiple cores... we have to cross our fingers it will get fixed soon...!
Posted: Tue Sep 28, 2010 12:32 am
by freecartman™
funksmaname wrote:this is a recently descovered issue with the multithread rendering
And does it work fine on AS6?
Posted: Tue Sep 28, 2010 1:08 am
by funksmaname
yep
Posted: Tue Sep 28, 2010 2:06 am
by freecartman™
ok i used the "combo" on AS6 so now i can export the animations but i have 2 problems
1) i always have a Lua conole's window saying: Meshinstance:wrong order- swap the source and the copy
2) after exporting the "dup" layers don't move, but just the source layers do the action...here it is (sry but it's very very short) an eg.
http://www.youtube.com/watch?v=iHfkVp7nWuU
Posted: Tue Sep 28, 2010 2:27 am
by funksmaname
are the dupes deffinately working in the program?
Try using this one:
viewtopic.php?t=12024&highlight=meshinstance
Posted: Tue Sep 28, 2010 12:29 pm
by freecartman™
as we say "liscio come l'olio"!!!!
it works fine!! thank you funks!!
Posted: Wed Dec 01, 2010 7:05 am
by Vagabond
This is exactly why being able to save in earlier versions of Anime Studio is essential.
Re: embed script drop down
Posted: Thu Aug 08, 2013 10:17 pm
by Víctor Paredes
Hi, I just discovered this thread and this script is exactly what I was looking for, but I can't make it work.
Do you know if does it work in version 9? If the answer is No, do you know how to fix it?
Thanks.
