Page 2 of 2
Posted: Wed Apr 20, 2005 8:54 am
by jakob polack
hey thanks...I tried out your tutorial - works...I wonder if I wnt to really import 3d into moho or work with characters in moho and make the composite with background (3D) in max...hmm - if you know a place with good wings tutorials . let me know...:-) jakobPcpc
Posted: Wed Apr 20, 2005 9:06 am
by jakob polack
hey thanks- usefull- know any good websites for wings tutorials. :-) jakobpcph
Posted: Wed Apr 20, 2005 10:15 am
by jorgy
Glad the tutorial worked for you!
Except for the wings3d page itself, I've only found one other page that's been of help to me:
http://www.claypixels.com/tikiwiki/tiki-index.php
There is also another thread on the forum here:
http://www.lostmarble.com/forum/viewtopic.php?t=1446
that may be of interest to you too. 7feet has written some incredible scripts to shade imported 3d objects. In order to use a model imported from wing3d, you must assign "materials" to the surfaces, not "textures". The details are in that thread.
Posted: Mon May 16, 2005 1:57 pm
by nobudget
Jorgy, thanks for the step-by-step tutorial. I tried Wings3D for the first time today and I just wanted to map a simple image to a side of a cube and couldn't figure it out. I couldn't find it in the manual at first glance, not in the tutorials, but your solution worked the first time! But is this really the normal way? It seems very intricate and needs a paint program to "fake" the content of the image file?
Is Wings3D considered a decent program? I use it because Moho needs .obj files but it doesn't feel like a solid piece of software at first glance. Anim8or works much better for me, is also free but no .obj export...
Anyway, thanks, I can experiment with 3D in Moho now!
Reindert.
www.nobudgetvideo.com
Posted: Mon May 16, 2005 2:29 pm
by Hiddicop
Isn't it easier to simply do the 3D-object in Anim8or and export it to another format than OBJ, and then import that file to Wings3D and export to OBJ? Can't you simply use Wings3D as an converter?
Posted: Mon May 16, 2005 4:02 pm
by nobudget
I'm not sure, I haven't tried that. It's been a while since I last used anim8or, I don't know the export formats. It's worth a try, thanks!
Reindert.
Posted: Mon May 16, 2005 6:46 pm
by jorgy
nobudget wrote:Jorgy, thanks for the step-by-step tutorial. I tried Wings3D for the first time today and I just wanted to map a simple image to a side of a cube and couldn't figure it out. I couldn't find it in the manual at first glance, not in the tutorials, but your solution worked the first time! But is this really the normal way? It seems very intricate and needs a paint program to "fake" the content of the image file?
Reindert.
I'm glad that I was able to help! Just wanting to return some of what I've received on this forum.
As far as this method for doing materials, I'm not sure if it's the best. It's the only way I know of to put an arbitrary picture on a 3d object. And is it robust? In my experience it has been, no crashes, etc. The only real gotcha is remembering to triangulate before importing into moho so that 7ft's script will work properly.
jorgy
Posted: Tue May 17, 2005 10:58 am
by CrAzY Dan
I use anim8or as i have just found out you can export to .obj and i find it easier to do.
Posted: Tue May 17, 2005 3:22 pm
by nobudget
Yep, anim8or can export .obj but I can't get the texture out... The texture is embedded in the .obj file (or is it?) but Moho doesn't see the texture map, only the shape. Converting in Wings3D doesn't seem to improve this...
Reindert.
