Posted: Mon Apr 06, 2009 2:12 pm
thanks for the comment
i make my walk cycles based on a tutorial i found on youtube.
4 stages = contact, recoil,passing, high point (these are for the legs)
still messing about with the upper body, trying to find a fast way of making the arm and upper body movement for the run cycle.
the biggest problem was the gun he is holding, usually when you run you swing the gun from side to side, but that exposes the 'hidden face' of the gun. so i had to keep the arm singing to a minimum.
will try to find a way around that the next time
