Posted: Tue Oct 07, 2008 6:47 pm
Hey Synth
I saved the file before applying scripts.
So I'll try adding the roof, then regenerate rigging.
My only concern is this:
If I add the roof, then copy and paste the geometry to the other view
(and then edit for that view obviously)
Will that actually work?
I ask because I know that duping the layer maintains the correct
point order. But I have already duplicated and edited the layers
and don't particularly want to go thru all that again.
So I'm wondering if copying and pasting between layers will work,
or will I get errors (as I have in the past with this,
and the fix was to dupe the layer, as Genete said in his tute.)
Is there scripting access to point order numbering or something?
Rig editing would be useful.
Not a big drama I suppose but that flexibility would be useful.
Tell me, do I understand you correctly in thinking
that you mean I should split the headlight thru the middle
vertically?
If so I'll give that a shot. Would be good to "anchor" the headlight.
The thing with the tires isn't that interesting and having read your solution
I think I made it needlessly complicated.
Basically the same thing, just that the tire geometry
started out hanging off either side of the wheel.
And now I've realised I dont have a rear face to the wheel, so
you can see "into" the wheel from behind at the moment.
Easy fixed.
Dude, now that you say it, I DO need the tires to both
spin and steer. Especially steer, but spin would be great also.
Good thinking.
What do I do, seperate rig on seperate layers?
vertically?
Easy fixed.
Good thinking.
