Posted: Wed Dec 12, 2007 9:50 pm
Yes, you're right. Steps are:DK wrote:Ahh...thanks Genete. I'll try that instead of closing it.
EDIT: This is a handy script but it seems to me that you have to maipulate each point to an x,y co-ordinate then run the freeze script so that when the shape moves through these particular co-ordinates the points will not pass?. Is this correct?
D.K
- Draw in frame 0 as usual.
- At other frame morph your composition to the X or Y maximum positions. It can be different values for each point. It depends on what you want to achieve. For a drop effect you have to flatten the shapes (Scale tool).
- Being at that frame, run the menu/tool script. It would store the points positions.
- Remove the keyframe created (if desired)
- That's all, now animation!
