How to make a snake creeping
- toonertime
i am cured
thanks for the insight! I think I was adjusting the bones at frame 0
i moved the bones around on different frames and got my
little worm to wiggle! Not in front of the kids, tho.
- toonertime
- toonertime
text test
the above url just shows a quick test I did using
text and running them over some bones to
make a fluid movement. Great, simple technique!
Re: text test
good job!toonertime wrote:the above url just shows a quick test I did using
- TheChewanater
For any Blender users, someone asked on the Nystic forums how to do this, and I did it in Blender. If you want to see it, here's the link: http://www.freewebs.com/chewanater/slither.blend
stardvd555
Ok, here is a dragon from a project I'm working. I wanted to post the finished 8 shorts we are making, but I couldn't resist to put this animation here
Dragon swf (just open the link in a new tab).
I couldn't open your dragon, but damn! Thanks for posting this thread, I never would have thought of that.
joelstoryboards.com - (WinXP SP3, ASP 6.1)
try copying and pasting this linkBlue wrote:I couldn't open your dragon, but damn! Thanks for posting this thread, I never would have thought of that.
http://www.freewebs.com/tazatriste/moho ... o%2012.swf
Here's another way to use the technique in AS. I tried to duplicate a magnifying glass video I saw on YouTube. Since I have to move the image layer instead of the bone layer I wonder if that video was done in another program.
http://www.youtube.com/watch?v=D8HeAVshRAQ
Nice use of the technique by Toonertime too. I couldn't view the wavy water effect. I was thinking of heat waves rising from a street too. Just need to keep the image still and move the bones.
Uhhh?
Hepglon no get it?
- fracturedray
Using the tips here I did a few test because I wanted to see if it could be used for water ripples in some way.
I tried scaling the bones to distort the shape as it flowed along the bones. Distorted the shape using columns of bones in a line as well as some other columns set up like a comb's teeth with scale/position changes.
All in all it was interesting to see how it worked and I may use what I've learned. Just need to do a little more testing.
Here the file if you wanted to see how I tinkered with the idea.
http://www.mediafire.com/?xtf13i1n24r8toc
Hi animation world.
