Joints
Joints
I spent some time today developing a good way of creating joints that bend and overlap correctly while still maintaining their shape. I thought I'd share the results with you all.
Here's a swf preview:
http://www.jordanleary.com/mohojoints.html
And here's the Moho file:
http://www.jordanleary.com/mohojoints.zip
Enjoy. You know what they say...
"Give a man a fire and he'll be warm for a day. Set a man on fire and he'll be warm for the rest of his life."
- Green Walls
Thank you for sharing this, it looks very nice... Could you post a message describing what you did and how you did it, to help me re-create it... Looking at it is interesting, but learning how to do it would be more beneficial to me... Specifically the body itself, it looks like a single shape, but I'm assuming it's not?
Celeryhart
I have looked and looked at this file, and have tried to create an arm the same way (specifically the overlapping part) and just can't seem to figure it out.jordanek wrote:wizaerd,
The body consists of several shapes. It looks like a single shape because they all share some of the same points. There are shapes for the forearms, the biceps, and then the main body. It's necessary to have multiple shapes to make overlapping work.
This is an instance where seeing the final product doesn't really tell me how to create it. I have the points assigne correctly according to the example, but I still get that overlap space... WHat steps do I follow to create an overlapping arm?
I get the bone setup, that's actually the easy part. What I can't figure out really has nothing to do with the bones themselves, but with the shapes and how they were made.
Open his example, and go into Bone Manipulate mode. Rotate the two main bones (not the fan or cog bones as they're also known as), and notice there's no overlap in the lines.
It has something to do the arm being three seperate shapes, yet along internconnected control points.
Hi again Wizaerd,
When i played around with his technique, creating my own test 'body' it seemed to work fine.
are you using flexible binding or regional?
Actually, when i did it i used regional and binded the points to the bones etc like it is mentioned in the manual
I will try it again and post it for you..see if there are any differences with each of our versions. The only difference i think is that i am using region binding
They are set to Region binding, and the points are assigned correctly. Beside not being a full character, the bones setup is the same as in jordanek's example. (I don't believe that flexible or region matters if assigning points, but I did try it both ways)
Unless I'm being particularly dense, again, this has nothing to do with bones. Create a rectangle. Give it a fill and an outline so you can see this better. Along the bottom section of the rectangle, add two more points. Then translate each of them across from each other
That's overlap, and the placement of the bones in jordanek's example doesn't control that. Its the shapes and how they were constructed and conencted.
