getting group name
davoodice2
getting group name
Post by davoodice2 »
hi
is there function to get parent of layer that is not selected?
for example
moho.layer:Parent("layerName")
Re: getting group name
As long as you're storing the unselected layer object (moho.layer) to a variable, even with it unselected, you can do:
var:Parent()
and
var:Parent():Name()
davoodice2
synthsin75 wrote: Tue Aug 31, 2021 4:57 pm As long as you're storing the unselected layer object (moho.layer) to a variable, even with it unselected, you can do:
var:Parent()
and
var:Parent():Name()
thanks. and how can I select a layer ? SetSelLayer()? what is it's argument? is there any better way?
I want store current selected layer to select it later.
how to get current selected layer ID?
if you've got the current active layer and decided that the right thing is to select a different one, make sure that you have a variable that addresses a MohoLayer object (e.g. var = moho.layer:Parent() to get the active layer's parent) then
moho:SetSelLayer(var) will selected the layer identified by "var" in the layers window
ScriptInterface:SetSelLayer(layer, multiSelect, allowDeselect) : see https://mohoscripting.com/methods/60
As Wes has said, you don't need the layer to be selected to work on it ... so (e.g.) you can find the parent, then do something with some / all the child layers but still leave the one original child layer selected
davoodice2
hayasidist wrote: Tue Aug 31, 2021 6:30 pm if you've got the current active layer and decided that the right thing is to select a different one, make sure that you have a variable that addresses a MohoLayer object (e.g. var = moho.layer:Parent() to get the active layer's parent) then
thanks. but can you give me an example of 2 line code for store current layer and select that later? I dont understand var in lua. Take it easy on me
function DV_select_Bone_Layer:Run(moho,group)
	local isFound = false
	local prev_name = moho.layer:Name()
	local parent = moho.layer:Parent()
	if (parent == nil) then
		LM.Beep()
		moho:SetSelLayer(prev_name)
		return -1
	end
	moho:SetSelLayer(parent)
	local layet_type = moho.layer:LayerType(parent)
	if(layet_type==MOHO.LT_BONE) then
		isFound=true
		return -1
	end
    while not isFound do
		if parent == nil then
			LM.Beep()
			print(prev_name)
			break
		end
			isFound=true
		end
	end
end
moho:SetSelLayer(prev_name) doesn't work
SetSelLayer doesn't accept names, as more than one layer could have the same name. It needs the layer object.
local layer_object = moho.layer
moho:SetSelLayer(layer_object)
davoodice2 wrote: Tue Aug 31, 2021 7:10 pm thanks. but can you give me an example of 2 line code for store current layer and select that later? I dont understand var in lua. Take it easy on me
var is just an arbitrary variable name
replace the name "layer_object" that Wes used with "var"...
local var = moho.layer
If you're struggling with Lua: Moho currently uses 5.2: http://www.lua.org/manual/5.2/
davoodice2
Perfect!
thank you two friends.
davoodice2
davoodice2 wrote: Tue Aug 31, 2021 6:04 pm
var:Parent()
and
var:Parent():Name()
Can i select parent layer of a layer that isn't selected ?
yes - as long as you have (or can get) the MohoLayer object for the layer whose parent you want -- it doesn't have to be the selected layer -- e.g.
you have a selected layer: (moho.layer)
you find its parent: parent = moho.layer:Parent() (which is not the selected layer!)
and now you want the "grandparent": gp = parent:Parent()
if you then want to make that the selected layer: moho:SetSelLayer(gp)
or if you just want to see all the gp's children..
gp = moho:LayerAsGroup(gp)
for i = 0, gp:CountLayers()-1 do
.. child = gp:Layer(i)
davoodice2
hayasidist wrote: Thu Sep 02, 2021 1:18 pm yes - as long as you have (or can get) the MohoLayer object for the layer whose parent you want -- it doesn't have to be the selected layer -- e.g.
its related to current selected object. I want to select parent of a layer that isn't select now. for eg:
i selected foot layer. but I want to select parent of head layer.
davoodice2 wrote: Thu Sep 02, 2021 2:22 pm its related to current selected object. I want to select parent of a layer that isn't select now. for eg:
Store the head layer object to a variable and you can select its parent layer any time you like.
And if you haven't stored the layer object, as long as you have some way to identify the layer, like unique name, tag, UUID, etc., you can always iterate through all the layers in the document until you find it: https://mohoscripting.com/snippets/1
davoodice2
synthsin75 wrote: Thu Sep 02, 2021 5:20 pm
if want to tell more clearly. I select a layer and i want to find all parents of this layer and do some thing on them. use for loop or some thing like that.
I think it isn't good if i write:
moho.layer:Parent():Parent():Parent():.....
davoodice2 wrote: Fri Sep 03, 2021 5:51 am I think it isn't good if i write:
that will work unless you hit the end of the "family tree" -- see my previous post about getting a grandparent -- add to that a test to see if there's a parent.. e.g if not gp then ...
if parent then
	if gp then ...
or you can get cute and use recursion to seek out the root:
function getParent (layer)
	local parent = layer:Parent()
	if parent then
		getParent (parent)
end
davoodice2
hayasidist wrote: Fri Sep 03, 2021 9:11 am
if parent then
	if gp then ...
	if parent then
		getParent (parent)
end
Oh God how dumb I am.
I had think I can get parent just with moho.layer:Parent()
now i find out layer:Parent() because of inheritance
