Switch Layer Labels on Timeline
teotoon
Post by teotoon »
Hello Folks,
Is it possible to make appear the individual switch layers' names on the timeline?
Lukas
Re: Switch Layer Labels on Timeline
Post by Lukas »
Unfortunately not.
But you could give the switchlayers color labels, and the keys will automatically be labeled with those colors.
Edit: Hmmm, it could probably be scripted with markers though... I'll look into it, because I could use it myself too.
SimplSam
Post by SimplSam »
If you mean showing the switched to 'switch layers' names on the switch timeline, then they are hiding there as a tool-tip when you hover over the start of the switch keyframe.
I was also going to suggest it could be added via layer markers in a script. :D
Lukas
Post by Lukas »
SimplSam wrote: Mon Jul 19, 2021 12:51 amI was also going to suggest it could be added via layer markers in a script. :D
Got it to work! :)
Posted the script in the scripting section, here's the post
SimplSam
Post by SimplSam »
Looks fantastic - will give it a whirl later.
