Layer Ordering
Layer Ordering
I was setting up a character the other day in Moho when I realised that a function I take for granted in other animation software is completely lacking in Moho, namely the ability to switch around layer orders during a scene.
At present, the order is fixed for the whole scene.
There are various ways of working round this, but they are fiddly.
I'd like to be able to drag layers up and down at different frames and have their orders change accordingly. Does anyone else think this would be useful?
Jeff
Jeff
That would be really awesome!  I'd love to be able to have a character move his hand from behind something to in front of it.  Right now you could do it with duplicate layers and keyed visibility, but then if you needed to change anything, you'd need to reduplicate and key.
This would ROCK!
________
Ipad Guide
													This would ROCK!
________
Ipad Guide
				TheTallGuy
Yeah, it would be cool if you could simply drag a layer up in the timeline while holding a modifier key, and it split somehow.  Though my eyes start to cross when I think about how you actually represent that in the user interface.
Right now, I believe you can do something very much like that by adjusting the layer depth, which is keyable. On the timeline, the hand layer will still look like it's behind the body, but in the preview it will pop in front.
I suppose it's as easy as trying it myself, but since I'm at work and can't try until later (and I just can't wait).  Can you key layer depth on a layer that's being controlled by a bone?
For instance, say your characters hand moves behind a table, then you want him to put it on top of the table. Is it as simple as using the depth settings? Oooh, I'm giddy just thinking about the possibilities! So simple and clean.
________
MONTE CARLO
________
MONTE CARLO
				TheTallGuy
- Lost Marble
Sweet!  That is a perfect solution to the hand in front of and on top of the table.  Any other solution (like keying layer order) would probably make things more complicated.
Is there anything Moho can't do?!? I love it!
Thanks!
________
Vaporizer wholesaler
Thanks!
________
				TheTallGuy
- Lost Marble
Actually, if you go to File->Project Settings and turn on "Sort layers by depth", Moho will sort the top-level layers. If you just want to sort the lsyers within a single group (or bone) layer, double-click that group layer. Then in the Layer Settings dialog, go to the "Depth Sort" tab and turn on "Sort layers by depth".
Also, if you still have version 4 around, check out Tutorial 16 in the manual.
