export animation with transparent backgroud
skygaz3r
Post by skygaz3r »
hello guys,
i was wondering if it is possible to export a single frame or an entire animation with a transparent background.
I want to design some tshirts and for that purpose it would be nice to export a single frame/picture with a transparent background and maybe even as a vector.
is it possible to export an entire animation with a transparent background? had the idea to combine animatione maybe with some "real life" stuff.
sorry, my english isn't good ;(
Re: export animation with transparent backgroud
Export as PNG.
skygaz3r
Post by skygaz3r »
Thanks a lot :D That simple xD
And how can i do this for a entire animation? Because if i export as PNG and the animation has a couple of frames each frame gets exported as a single image
skygaz3r wrote:Thanks a lot :D That simple xD
You can export Quicktime>PNG>Millions colors
skygaz3r
Post by skygaz3r »
Thanks im going to try this :)
Mikdog
Post by Mikdog »
For a single image, you can render the frame and save as PNG instead of JPEG, gets saved with transparency afaik.
For an entire animation, as slow mentioned, export as a Quicktime movie using the .PNG codec, in the settings before export select 'Do not pre-multiply alpha channel' and if you have the option for the codec, choose 'Millions of Colors +' (the '+' denotes the alpha channel / transparency)
wizaerd
Post by wizaerd »
I know a lot of times people export their videos as image sequences, in order to work in some post-processing... but I'm curious what happens to the audio if someone does this?
Danimal
Post by Danimal »
If exported as images, there would be no audio. You'd need some kind of external video editor which you could then use to sync the video and audio back up.
~Danimal
If you export animation as image sequence, the sound will be exported as sheet music, of course.
