EPS import
sbtamu
EPS import
Post by sbtamu »
I decided to try and import some of my hand drawn images as vector in to AS 7 pro. I downloaded Inkscape and managed to get results that looks good enough to 'save as.' When I save it as EPS and try an import it to AS I can see the upload bar but It does not create the new layer with the vectors.
Any tips would be greatly appreciated
Thanks
Stephen
Sorry for bad animation
neeters_guy
Post by neeters_guy »
Trace the image in Inkscape, save as svg. Use Uniconvertor to convert the svg file to ai. Import the ai into AS. This worked when I tried it, but you may have to fix the color of the shapes.
Here's the download for Uniconvertor (Windows/Linux):
UniConvertor 1.1.5 release packages
sbtamu
Post by sbtamu »
neeters_guy wrote:Trace the image in Inkscape, save as svg. Use Uniconvertor to convert the svg file to ai. Import the ai into AS. This worked when I tried it, but you may have to fix the color of the shapes.
Thanks neeters_guy, I will try that when I get home later today. There is no color, its black ink on typing paper.
